StarTech.com 1m USB to Type N Barrel 5V DC Power Cable - USB A to 5.5mm DC
Quicklinx: 8D6XWS00 Mfr#: USB2TYPEN1M
Length: 1m
£5.17 ex VAT
£6.20 inc VAT
Power your 5V DC devices from your computer through a USB port. Tired of having to carry around a separate wall adapter in order to power or charge your 5V devices, such as certain external hard drives, streaming media players, and Bluetooth speakers?
This 1m USB power cable makes it easier to power 5V DC devices that have a Type N barrel power connector. You can power or charge the devices through an available USB port on your laptop or desktop computer.
  • Durable construction
    The molded design of this power cable enhances its durability, allowing it to endure regular wear and tear over time.
  • Flexible usage
    At 1 m in length, this cable provides ample length for connecting devices without hindering movement or creating a cluttered workspace.
  • Reliable connections
    With a 4-pin USB Type-A male connector on one end and a male 5.5 mm DC jack on the other, the cable ensures a secure and stable power connection for various applications.
  • Environmentally friendly
    This cable is RoHS compliant, indicating that it adheres to safety standards that limit hazardous substances, promoting safer usage.
StarTech.com 1m USB to Type N Barrel 5V DC Power Cable - USB A to 5.5mm DC - 1 Meter USB to 5.5mm DC Plug (USB2TYPEN1M) - power cable - USB (power only) to DC jack 5.5 x 2.5 mm - 1 m
Power cable
Shielded
Molded, strain relief
Length
1 m
Connector
4 pin USB Type A (power only) - male
Connector (Second End)
Power DC jack 5.5 mm (ID: 2.5 mm) - male
P/N: HDBOOST
Power cable
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
RoHS
P/N: HDBOOST
8D6X StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £5.27
8D6X StarTech.com 2m USB to Type M Barrel Cable - USB to 5.5mm 5V DC Cable In Stock £5.65
8D6X StarTech.com 1m USB to Type N Barrel 5V DC Power Cable - USB A to 5.5mm DC In Stock £5.17
Length: 1m
