This USB to Lightning cable withstands the daily demands of charging and syncing your mobile devices. Tested to endure strenuous wear and tear and winter and summer in-car use, the rugged cable is a must-have for both business and consumer applications.
The durable Lightning cable has a Dupont Kevlar reinforcement that shelters it from the stress of frequent bends and twists. This also lets the cable flex without over-stretching, and strengthens the core of the cable.
Cable Key Features. Kevlar aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features. Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
RUSBLTMM1MB is an Apple MFi certified Lightning cable.
Built for daily use
The durable Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the cable flex without over-stretching, and strengthens the core of the cable. -
Apple MFi-certified
USB-A to Lightning adapter cable for guaranteed fast and reliable charge/sync from USB Type-A charger port for lightning devices.
- StarTech.com 3 ft(1m) Durable Black USB-A to Lightning Cable, Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charger/Sync Power Cord, Apple MFi Certified iPad/iPhone 12 Pro Max - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 1 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 22/32
- Length
- 1 m
- Black
- Connector
- USB - male - straight
- Connector (Second End)
- Lightning - male - straight
- Strain relief
- 2-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 22/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Strain relief
- Black
- Connector
- 4 pin USB Type A - male - straight
- Apple Lightning - male - straight
- MFI
- Limited warranty - 2 years
StarTech.com 1m USB to Lightning Cable | In Stock | £12.30 |
StarTech.com 1m USB to Lightning Cable - Black | In Stock | £12.96 |
StarTech.com 1m / 3.3ft Angled Lightning to USB Cable | In Stock | £13.14 |
StarTech.com 1m / 3.3ft Angled Lightning to USB Cable - White | In Stock | £11.50 |
StarTech.com 2m / 6.6ft Angled Lightning to USB Cable - Black | In Stock | £14.46 |
StarTech.com 2m / 6.6ft Angled Lightning to USB Cable -White | In Stock | £14.40 |
