Quicklinx: CHN3WS00 Mfr#: CDP2HDMM1MB
More than 50 in stock
£20.91 ex VAT
£25.09 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television or projector. The adapter supports a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, a 2 m (6 ft.) USB-C to HDMI cable enabl you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display.
The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Clutter-free installation
  • Hassle-free connection with USB Type-C
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
StarTech.com USB C to HDMI Adapter Cable - USB Type-C HDMI - 4K 30Hz - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI (male connector)
Length
1 m
Bus Type
USB-C
Max Resolution
3840 x 2160
FCC, RoHS, WEEE
Length
1 m
45 °C
5 - 95% (non-condensing)
Price Range Ex VAT: 0 - 50
