Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television, or projector. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
Clutter-free installation
While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports HDMI. At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation.
For longer installations, StarTech.com also offers a 2 m (6 ft.) USB-C to HDMI cable (CDP2HD2MWNL) and a 3 m (10 ft.) USB-C to HDMI cable (CDP2HD3MWNL), enabling you to choose the right cable length for your custom installation needs.
Astonishing picture quality
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
The CDP2HD1MWNL is backed by a 3-year StarTech.com warranty and free lifetime technical support.
While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports HDMI. At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation. -
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60 Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60 Hz implementation.
- StarTech.com 3ft (1m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, White - 4K USB-C Video Cable (CDP2HD1MWNL) - adapter cable - HDMI / USB - 1 m
- Cable
- Adapter cable - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 1 m
- White
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- HDMI - male (output)
- Displayport 1.2/Thunderbolt 3
- 4K60Hz (3840 x 2160) support
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Cable Type
- Adapter cable 4K60Hz (3840 x 2160) support
- Interface Supported
- HDMI / USB
- Length
- 1 m
- HBR2 audio support, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- White
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Linux, Android, Google Chrome OS, Windows 10, Apple iPadOS
- Connector
- 19 pin HDMI Type A - male (output)
- FCC, RoHS, HDCP 2.2, HDCP 1.4
- 50 g
- Shipping Width
- 2 cm
- Shipping Depth
- 110 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 50 g
- Limited warranty - 3 years
- Designed For
- P/N: TB4CDOCK
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.69 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £26.55 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £26.93 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £26.60 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £22.41 |
StarTech.com 3m USB-C to DVI Cable - Black | In Stock | £23.41 |
