StarTech.com 1m USB C to HDMI Cable - Black
Quicklinx: D9KHWS00 Mfr#: CDP2HD1MBNL
Length: 1m
Select:
More than 50 in stock
£22.13 ex VAT
£26.55 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television, or projector. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For longer installations, StarTech.com also offers a 2 m (6 ft.) USB-C to HDMI cable (CDP2HD2MBNL) and a 3 m (10 ft.) USB-C to HDMI cable (CDP2HD3MBNL), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
StarTech.com 1m / 3 ft USB C to HDMI Cable - 4K at 60 Hz - Black - external video adapter - VL100 - black
External video adapter
Bus Type
USB-C
Graphics Engine
VL100
Max Resolution
3840 x 2160
HDMI (male connector)
2.2 cm 1.4 cm
Length
1 m
Enclosure Colour
3-year warranty
Bus Type
USB-C
Graphics Engine
VL100
Max Resolution
3840 x 2160 at 60 Hz
HD/4k Ready, 7.1 channel surround sound ready, Thunderbolt 3 compatible
FCC, RoHS, WEEE, RCM
2.2 cm
1.4 cm
Length
1 m
80 g
Enclosure Colour
Limited warranty - 3 years
45 °C
5 - 90% (non-condensing)
D9KH StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £26.93
D9KH StarTech.com 2m USB-C to HDMI Cable In Stock £24.08
D9KH StarTech.com 2m USB C to HDMI Cable - Black In Stock £24.08
D9KH StarTech.com 1m USB C to HDMI Cable - Black In Stock £22.13
D9KH StarTech.com 3m USB C to HDMI Cable - Black In Stock £26.02
D9KH StarTech.com 1m USB C to HDMI Cable - White In Stock £22.13
D9KH StarTech.com 2m USB C to HDMI Cable - White In Stock £24.08
D9KH StarTech.com 3m USB C to HDMI Cable - White In Stock £27.39
Length: 1m
Price Range Ex VAT: 0 - 50
