- USB TYPE-C CHARGING CABLE: High quality USB-C to C cable delivers 3A output for fast charging portable USB-C devices; Connects to a USB-C wall charger or power bank; USB Power Delivery charges USB-C laptops and tablets up to 60W.
- QUALITY CONSTRUCTION: Nickel-plated connectors rated beyond 10,000 insertion cycles; Robust strain reliefs with 8mm bend radius; Durable TPE outer jacket is non-toxic, halogen-free and RoHS compliant; Aluminum braided shield for enhanced EMI protection.
- APPLICATIONS: Compatible with USB-C Power Delivery-enabled devices; Ideal for fast charging small peripherals; Supports USB 2.0 for general use, including file transfer and device synchronization when connected to a USB-C host computer or external storage.
Efficient power delivery
Equipped with USB Power Delivery (60 W), this 1 m (3 ft) USB C Charging Cable ensures fast and efficient charging, delivering up to 60 W of power to your devices. Ideal for laptops and other high-power devices, it supports a wide range of voltage levels from 5 V to 20 V. -
Durable design
The cable features a robust Thermoplastic elastomer (TPE) jacket, providing a flexible yet durable construction. Enhanced with strain relief and a halogen-free composition, it's designed for long-lasting use while being environmentally friendly. -
High-quality connectivity
Featuring nickel-plated connectors and shielded with aluminum mylar foil with a braid, this USB-C cable ensures a reliable connection with minimal interference. It supports USB 2.0 for data transfer, making it suitable for syncing and charging your devices.
- StarTech.com 1m (3ft) USB C Charging Cable, USB-C Cable, USB 2.0 Type-C Laptop Charger Cord, 60W 3A Power Delivery, TPE Jacket, USB-C Data Transfer Cable, M/M - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- USB Power Delivery (60W), sync and charge, strain relief, halogen free
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 5 / 9 / 12 / 15 / 20 V
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- 2-year warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 24/30
- Rated Voltage
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 3.5 mm
- Black
- Connector
- USB / USB 2.0, RoHS, WEEE, EMI
- Shipping Width
- 22.5 cm
- Shipping Depth
- 12.5 cm
- Shipping Height
- 1 cm
- 2-year warranty
StarTech.com USB-C Charging Cable, 240W PD - 1m | In Stock | £12.17 |
