StarTech.com 1m USB-C Charging Cable
Quicklinx: HM0YWS00 Mfr#: USB2CC1MNC
Length: 1m
More than 50 In Stock
£5.03 ex VAT
£6.03 inc VAT
  • USB TYPE-C CHARGING CABLE: High quality USB-C to C cable delivers 3A output for fast charging portable USB-C devices; Connects to a USB-C wall charger or power bank; USB Power Delivery charges USB-C laptops and tablets up to 60W.
  • QUALITY CONSTRUCTION: Nickel-plated connectors rated beyond 10,000 insertion cycles; Robust strain reliefs with 8mm bend radius; Durable TPE outer jacket is non-toxic, halogen-free and RoHS compliant; Aluminum braided shield for enhanced EMI protection.
  • APPLICATIONS: Compatible with USB-C Power Delivery-enabled devices; Ideal for fast charging small peripherals; Supports USB 2.0 for general use, including file transfer and device synchronization when connected to a USB-C host computer or external storage.
  • Efficient power delivery
    Equipped with USB Power Delivery (60 W), this 1 m (3 ft) USB C Charging Cable ensures fast and efficient charging, delivering up to 60 W of power to your devices. Ideal for laptops and other high-power devices, it supports a wide range of voltage levels from 5 V to 20 V.
  • Durable design
    The cable features a robust Thermoplastic elastomer (TPE) jacket, providing a flexible yet durable construction. Enhanced with strain relief and a halogen-free composition, it's designed for long-lasting use while being environmentally friendly.
  • High-quality connectivity
    Featuring nickel-plated connectors and shielded with aluminum mylar foil with a braid, this USB-C cable ensures a reliable connection with minimal interference. It supports USB 2.0 for data transfer, making it suitable for syncing and charging your devices.
StarTech.com 1m (3ft) USB C Charging Cable, USB-C Cable, USB 2.0 Type-C Laptop Charger Cord, 60W 3A Power Delivery, TPE Jacket, USB-C Data Transfer Cable, M/M - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Shielded
USB Power Delivery (60W), sync and charge, strain relief, halogen free
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
5 / 9 / 12 / 15 / 20 V
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
American Wire Gauge (AWG)
24/30
Rated Voltage
Rated Current
3 A
Plated Connector
Nickel
Length
1 m
Outside Diameter
3.5 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE, EMI
Shipping Width
22.5 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
HM0Y StarTech.com USB-C Charging Cable, 240W PD - 1m In Stock £10.10
HM0Y StarTech.com USB-C Charging Cable, 240W PD - 2m In Stock £11.40
HM0Y StarTech.com USB-C Charging Cable, 240W PD Black 3m In Stock £14.04
HM0Y StarTech.com USB-C Charging Cable, 240W PD Black 4m In Stock £15.40
Length: 1m
