StarTech.com 1m USB C Cable - USB 3.0
Quicklinx: D4FHWS00 Mfr#: USB315CC1M
Length: 1m
More than 50 In Stock
£11.09 ex VAT
£13.30 inc VAT
Connect your USB Type-C devices. This USB 3.0 USB-C to USB-C cable lets you connect a USB 3.0, USB Type-C device, such as a hard drive or mobile device, to the USB-C port on your computer, or charger. The cable is also compatible with Thunderbolt 3 ports.
Connect your newer USB-C mobile devices, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones, to your computer. The cable delivers up to a 3 amp (60W) charge, and supports data transfer speeds of up to 5Gbps.
With up to 3A of power output, you can also use the USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect your laptop to your USB-C wall charger.
You'll also be able to connect your USB 3.0 peripheral devices, such as hard drive enclosures and docks, to your laptop.
StarTech.com USB C to UCB C Cable - 3 ft / 1m - M/M - USB 3.0 (5Gbps) - USB C Charging Cable - USB Type C Cable - USB-C to USB-C Cable (USB315CC1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Double shielded
4K support, Power Delivery (PD) technology, 5 Gbps data rate
Length
1 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
P/N: KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, SV211HDUC, SV221HUC4K
USB-C cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
24/32
Length
1 m
43 g
Connector
D4FH StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.36
Length: 1m
