The 3ft (1m) USB-A to USB-C Charging Cable from StarTech.com is designed for reliable charge and sync functionality. This cable meets USB 2.0 standards and offers a 480 Mbps data rate, allowing efficient data transfer while ensuring a consistent power supply with a rated current of 3 A. It features strain relief and EMI protection, enhancing durability and performance during use. With its nickel-plated connectors and aluminum mylar foil with braid shielding, this cable endures up to 10000 insertions, providing long-lasting service for all your USB-C devices.
Constructed from halogen-free materials, the Thermoplastic elastomer (TPE) jacket ensures safety and environmental compliance. This cable supports USB Fast Charge at 15 W, making it an excellent choice for quickly powering up your USB-C enabled devices. The male-to-male connectors are compatible with a variety of devices, making it a versatile addition to any tech setup, whether at home or in the office.
Reliable performance
This USB-A to USB-C cable supports data transfer rates of 480 Mbps, ensuring fast and efficient performance for all your devices. -
Durable construction
Featuring a strain relief mechanism and aluminum mylar foil with braid shielding, this cable is designed to withstand frequent use. -
Fast charging capability
With a rated current of 3 A, this cable is capable of delivering fast charging up to 15 W, allowing you to power your devices swiftly. -
Safety compliant
Made from halogen-free materials and compliant with RoHS standards, this cable is a safe choice for both you and the environment.
- StarTech.com 3ft (1m) USB-A to USB-C Charging Cable, Charger Cord, M/M - USB-C cable - USB to 24 pin USB-C - 1 m
- USB-C cable
- Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 24/32
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 3 mm
- Black
- 21 g
- Connector
- USB / USB 2.0, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 0.8 cm
- Shipping Weight
- 26 g
