Connect your USB Type-C devices to your laptop or desktop computer. Need to connect your new USB Type-C device to a device with a traditional-style USB-A USB port? This 1m USB-C to USB-A cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all.
Moving large files or transferring movies can be done in seconds - at twice the speed of USB 3.0 and 20x faster than USB 2.0 - all while charging your device with up to 3A, where supported.
You'll also be able to connect your USB 3.1 peripherals, such as hard drive enclosures and docks, to devices with a USB-A port. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
Connect your newer devices to older computers; USB 3.1 is backwards compatible with previous USB devices.
- StarTech.com 3 ft 1m USB to USB C Cable - USB 3.1 10Gpbs - USB-IF Certified (USB31AC1M) - USB-C cable - 24 pin USB-C to USB Type A - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.1
- Black
- Works With Chromebook
- 2-year warranty
- Designed For
- P/N: 4SD4FCRU31C, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB30A4AIB, HB31C2A2CME, HB31C3A1CME, M2E1BMU31C, M2E1BRU31C, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C3, PEXUSB314A2V2, SDOCK4U313
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Black
- Connector
- USB 3.1, RoHS, USB-IF
- 2-year warranty
- Designed For
- P/N: 4SD4FCRU31C, BNDTBUSB3142, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKT30CVAGPD, HB30A4AIB, HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HBS304A24A, M2E1BMU31C, M2E1BRU31C, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312C3, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, S251BRU31C3, SDOCK4U313, TB33A1C
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £9.63 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.74 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.37 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.98 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.47 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.50 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.21 |
StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £9.58 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.11 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £17.80 |
StarTech.com 0.5m USB to USB-C Cable 10Gbps | In Stock | £9.03 |
