StarTech.com 1m USB 3.1 C to Micro-B Cable
Quicklinx: BFPFWS00 Mfr#: USB31CUB1M
Length: 1m
£10.24 ex VAT
£12.28 inc VAT
Connect USB Micro-B devices to your USB-C host, using this durable 1-meter cable. Need to connect a USB Micro-B device to a USB-C device? This 1m USB-C to Micro-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB 3.1 Micro-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
You'll also be able to connect older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
Connect your Micro USB 3.0 phone or tablet to your USB 3.1 laptop or desktop computer for syncing and charging. The cable can provide up to 3A for powering your devices, where supported.
  • Reliable performance
    Featuring USB 3.1 technology, this cable ensures rapid data transfer rates of up to 10 Gbps, facilitating efficient sync and charging between compatible devices.
  • Versatile compatibility
    Equipped with a male 24 pin USB-C connector and a male 10 pin Micro-USB Type-B connector, this cable accommodates a wide variety of devices.
  • Robust construction
    The double shielded design minimizes interference, while the nickel-plated connectors contribute to a durable and reliable connection that withstands daily use.
StarTech.com USB C to Micro USB Cable - 3 ft / 1m - USB 3.1 - 10Gbps - Micro USB Cord - USB Type C to Micro USB Cable (USB31CUB1M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
10 pin Micro-USB Type B - male
USB 3.1
P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312C3, PEXUSB312EIC, PEXUSB321C, S251BPU31C3, S251BU31315, S251BU31REM, SM21BMU31C3, SM22BU31C3R, SMS2BU31C3R
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB 3.1, RoHS, USB-IF
BFPF StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BFPF StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
BFPF StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
BFPF StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
BFPF StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
BFPF StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
BFPF StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
BFPF StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
BFPF StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
BFPF StarTech.com USB-C to Micro-USB Adapter M/F In Stock £4.59
BFPF StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
BFPF StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.59
BFPF StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
Length: 1m
