StarTech.com 1m USB 3.1 C Cable w/ PD (5A)
Quicklinx: CTWLWS00 Mfr#: USB31C5C1M
Length: 1m
11 In Stock
£25.63 ex VAT
£30.75 inc VAT
Power your USB Type-C devices. This USB-C cable with power delivery lets you power your USB Type-C devices from your USB-C laptop or charge your USB-C laptop from a USB-C wall charger. The USB 3.1 Gen 2 cable is also capable of high-speed data transfers up to 10Gbps. It's the all-in-one cable for both power and data.
With up to 5A (100W) of power output, you can use this USB Type-C cable to power your external drive from your USB-C laptop.
The cable also lets you power and charge a USB-C laptop, such as your Apple MacBook or Chromebook Pixel from a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of power delivery lets you charge your mobile devices faster than with a regular USB-C 3.0 cable. The cable is perfect for people on the move - decrease your charge times and make sure your mobile devices are ready, whenever you need them, while you're on the road.
The cable supports full 4K 60Hz video and DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's ideal for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.1 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
StarTech.com USB C Cable - 3 ft / 1m - with Power Delivery (USB PD) - Power Pass Through Charging - USB to USB Cord (USB31C5C1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
5 A
USB 3.1
P/N: CDP2HVGUASPD, DK30C2DAGPD, DK30C2HAGPD, DKT30CHCPD, DKT30CHPD3, DKT30CHVSDPD, DKT31CMDPHPD, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C2A2CME, HB31C3A1CB, HB31C3A1CME, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3, S251BRU31C3, SDOCK4U313, SV211HDUC, SV221HUC4K, TB33A1C
USB-C cable
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26/32
Rated Current
5 A
Plated Connector
Nickel
Length
1 m
43 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1, RoHS, USB-IF, WEEE
P/N: CDP2HVGUASPD, CDP2VGAUACP, CDP2VGAUCP, DK30C2DAGPD, DK30C2HAGPD, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPD3, DKT30CHPDW, DKT30CHVSDPD, DKT31CMDPHPD, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C2A2CME, HB31C3A1CB, HB31C3A1CME, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3, S251BRU31C3, SDOCK4U313, SV211HDUC, SV221HUC4K, TB33A1C
CTWL StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
CTWL StarTech.com 3m Active USB-C Cable, USB 3.2 In Stock £46.67
Length: 1m
