Connect USB 2.0 USB-B devices to your USB-C host. Need to connect your USB-B device to a USB-C device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Connect your older USB 2.0 peripheral devices, such as your printer or external hard drive, to newer computers, with data transfer speeds of up to 480 Mbps.
- StarTech.com USB C to USB B Printer Cable - 3 ft / 1m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB1M) - USB-C cable - USB-C to USB Type B - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C3A1CFB, HB30C3A1CFS
- USB-C cable
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.39 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.58 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.45 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.53 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £12.71 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £15.26 |
