Connect USB 2.0 USB-B devices to your USB-C host. Need to connect your USB-B device to a USB-C device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Connect your older USB 2.0 peripheral devices, such as your printer or external hard drive, to newer computers, with data transfer speeds of up to 480 Mbps.
Reliable connectivity
The 24 pin USB-C connector ensures a solid link between devices, supporting efficient data communications without delays or interruptions. -
Durable construction
With nickel plating on connectors, this cable is designed to resist corrosion and wear, providing long-lasting performance. -
Interference reduction
The double shielded design minimizes signal interference, enhancing the overall quality of data transmission for uninterrupted printing tasks.
- StarTech.com USB C to USB B Printer Cable - 3 ft / 1m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB1M) - USB-C cable - 24 pin USB-C to USB Type B - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C3A1CFB, HB30C3A1CFS
- USB-C cable
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £8.00 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £7.96 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.61 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.06 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.10 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £10.13 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.50 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.05 |
StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £8.80 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
StarTech.com 2m 6ft USB 2.0 C to B Cable | In Stock | £13.69 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £14.66 |
StarTech.com 3m USB 2.0 C to B Cable | In Stock | £16.73 |
StarTech.com 0.5m USB 2.0 C to B Cable | In Stock | £8.87 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £16.24 |
