StarTech.com 1m Thunderbolt 3 Cable White
Quicklinx: CY2QWS00 Mfr#: TBLT3MM1MW
Length: 1m
£32.60 ex VAT
£39.12 inc VAT
Provide twice the data transfer speed of any other cable type, enable full 4K 60Hz video, and power your devices with a single cable. This Thunderbolt 3 cable lets you connect to any Thunderbolt 3 port (USB-C) to deliver video and data to your Thunderbolt, USB, and DisplayPort devices. Plus, the cable can provide power for charging your devices, and you can link up to six Thunderbolt 3 devices as part of a daisy-chained connection.
This cable supports data transfer rates of 20Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at twice the speed of a USB 3.1 (10Gbps) cable. For example, you can transfer a 4K movie in less than a minute. When connected to a USB 3.1 device, the cable supports data transfer rates of 10Gbps.
The Thunderbolt 3 USB-C cable is fully compatible with all of your USB 3.1 Gen 2 devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook Pro or Chromebook, and USB-C peripherals, such as your portable drive or docking station.
The cable supports full 4K 60Hz video and DisplayPort 1.2, and is compatible with existing DisplayPort displays. It's perfect for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
This Thunderbolt 3 cable delivers up to 100W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure.
The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations.
  • Faster data transfers when connected to Thunderbolt devices
  • USB-C compatible
    The Thunderbolt 3 USB-C cable is fully compatible with all of your USB 3.1 Gen 2 devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook Pro or Chromebook , and USB-C peripherals, such as your portable drive or docking station.
  • Full 4K video
  • Versatile power delivery
  • Thunderbolt networking
    The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations. The TBLT3MM1MW is backed by a 2-year warranty.
StarTech.com 3.3ft (1m) Thunderbolt 3 Cable, 20Gbps, 100W PD, 4K Video, Thunderbolt-Certified, Compatible w/ TB4/USB 3.2/DisplayPort - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 1 m
Thunderbolt cable
4K support
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
White
P/N: CDP2HDUACP, CDP2HDUACPW
Thunderbolt cable
4K support
Length
1 m
White
Connector
24 pin USB-C - male
24 pin USB-C - male
CY2Q StarTech.com 2m Thunderbolt 3 20Gbps Cable In Stock £39.11
CY2Q StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £32.69
CY2Q StarTech.com 0.5m Thunderbolt 3 Cable In Stock £19.39
CY2Q StarTech.com 1m Thunderbolt 3 Cable White In Stock £32.60
CY2Q StarTech.com 2m Thunderbolt 3 Cable White In Stock £39.00
CY2Q StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £31.60
CY2Q StarTech.com 3ft USB4 Cable, USB-C 40 Gbps In Stock £23.86
CY2Q StarTech.com 6ft (2m) Thunderbolt Cable In Stock £81.56
Length: 1m
