StarTech.com 1m Thunderbolt 3 40Gbps Cable
Quicklinx: CMCZWS00 Mfr#: TBLT3MM1MA
Length: 1m
£63.41 ex VAT
£76.09 inc VAT
Provide four times the data transfer speed of any other cable type, enable dual 4K 60Hz video, and power your devices with a single cable. This Thunderbolt 3 (40Gbps) cable lets you connect to any Thunderbolt 3 (USB-C) port to deliver video and data to your Thunderbolt and USB devices. Plus, the cable can provide power for charging your devices.
This cable supports data transfer rates of 40Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at four times the speed of a USB 3.1 Gen 2 (10Gbps) cable. For example, you can transfer a 4K movie in seconds.
You can also use the Thunderbolt 3 cable to charge and sync your USB-C mobile devices.
The cable supports full 5K 60Hz and dual 4K 60Hz video for astonishing resolution, contrast, and color depth. It's perfect for connecting your Thunderbolt 3 docking station to your monitor and providing amazing digital video details. The cable supports Thunderbolt, 5K and Ultra HD displays.
This Thunderbolt 3 cable delivers up to 60W of power for charging a laptop. It lets you keep your Thunderbolt 3 devices powered without having to carry around an additional power supply.
The cable gives you an easy way to bridge multiple Thunderbolt 3 USB-C enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together, for easy PC migrations.
StarTech.com Active 40Gbps Thunderbolt 3 Cable - 3.3ft/1m - Black - 5k 60Hz/4k 60Hz - Certified TB3 Charger Cord w/ 100W Power Delivery (TBLT3MM1MA) - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 1 m
Thunderbolt cable
Double shielded
4K support, 5K support
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB / DisplayPort
P/N: CDP2HDUACP, CDP2HDUACPW, TB33A1C, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU, TBDOCKHDPBC
Thunderbolt cable
Double shielded
Shielding Material
Jacket Material
PVC
Plated Connector
Nickel
Length
1 m
70 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB / DisplayPort, FCC, RoHS
CMCZ StarTech.com 2m Thunderbolt 3 20Gbps Cable In Stock £39.59
CMCZ StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £33.07
CMCZ StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.64
CMCZ StarTech.com Hard Disk Drive Duplicator Dock In Stock £78.24
CMCZ StarTech.com Dual M.2 Enclosure - RAID In Stock £41.89
CMCZ StarTech.com 1m Thunderbolt 3 Cable White In Stock £32.70
CMCZ StarTech.com 2m Thunderbolt 3 Cable White In Stock £39.23
CMCZ StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £31.93
CMCZ StarTech.com 3ft USB4 Cable, USB-C 40 Gbps In Stock £19.86
CMCZ StarTech.com 6ft (2m) Thunderbolt Cable In Stock £80.26
CMCZ StarTech.com 1m USB4 Cable, USB-C 40 Gbps In Stock £20.01
CMCZ StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £18.91
Length: 1m
