Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCSC1 1m LC to SC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
- StarTech.com 1m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/SC - OS1 - LC to SC Fiber Patch Cable (SMFIBLCSC1) - network cable - 1 m
- Network cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Singlemode
- Length
- 1 m
- Connector
- 2 x LC single-mode - male
- Connector (Second End)
- 2 x SC single-mode - male
- Limited lifetime warranty
- Designed For
- P/N: SFPGLCSXMMST
- Network Cable Type
- Network cable
- Technology
- Singlemode
- Length
- 1 m
- Connector
- Designed For
- P/N: SFPGLCSXMMST
