Connect a SAS controller to four SATA drives. This internal mini-SAS to SATA cable provides a cost-saving solution for connecting a SAS or SATA controller to four SATA drives. It's the perfect replacement for your SFF data-storage cables.
The cable is compatible with 6Gbps SATA drives.
Efficient connectivity
The 1m Internal Mini SAS to SATA Cable facilitates a seamless connection between Serial ATA / SAS storage devices, ensuring a stable and reliable link for data transfer. -
High compatibility
Equipped with a 36 pin 4x Mini SAS HD (SFF-8643) plug and four 7 pin Serial ATA plugs, this cable supports a wide range of storage configurations, making it a versatile solution for various data management needs. -
Quality assurance
Adhering to RoHS compliant standards, this cable is manufactured with a commitment to environmental safety and high-quality material use, ensuring durability and longevity for all your storage needs.
 - StarTech.com 1m Internal Mini SAS to SATA Cable - SFF-8643 to 4x SATA (SAS43SAT1M) - SATA / SAS cable - 1 m
 - SATA / SAS cable
- Length
 - 1 m
- Connector
 - 36 pin 4x Mini SAS HD (SFF-8643) - plug
- Connector (Second End)
 - 4 x 7 pin Serial ATA - plug
 - Black & silver
 - Limited lifetime warranty
- Designed For
 - P/N: SFF86448PLT2
- Storage Cable Type
 - SATA / SAS cable
- American Wire Gauge (AWG)
 - 30
- Length
 - 1 m
 - Black & silver
 - 44 g
- Connector
 - RoHS
- Designed For
 - P/N: SFF86448PLT2
                        StarTech.com 2x SFF-8643 to 8644 Adapter | In Stock | £64.81 |
