Connect a SAS controller to four SATA drives. This internal mini-SAS to SATA cable provides a cost-saving solution for connecting a SAS or SATA controller to four SATA drives. It's the perfect replacement for your SFF data-storage cables.
The cable is compatible with 6Gbps SATA drives.
- StarTech.com 1m Internal Mini SAS to SATA Cable - SFF-8643 to 4x SATA (SAS43SAT1M) - SATA / SAS cable - 1 m
- SATA / SAS cable
- Length
- 1 m
- Connector
- 36 pin 4x Mini SAS HD (SFF-8643) - plug
- Connector (Second End)
- 4 x 7 pin Serial ATA - plug
- Black & silver
- Limited lifetime warranty
- Designed For
- P/N: SFF86448PLT2
- Storage Cable Type
- SATA / SAS cable
- American Wire Gauge (AWG)
- 30
- Length
- 1 m
- Black & silver
- 44 g
- Connector
- RoHS
- Designed For
- P/N: SFF86448PLT2
StarTech.com 2x SFF-8643 to 8644 Adapter | In Stock | £73.23 |
