StarTech.com 1m SFF-8643 to 4x SATA Cable
Quicklinx: CHN7WS00 Mfr#: SAS43SAT1M
Length: 1m
Type: SATA
22 In Stock
£26.96 ex VAT
£32.35 inc VAT
Connect a SAS controller to four SATA drives. This internal mini-SAS to SATA cable provides a cost-saving solution for connecting a SAS or SATA controller to four SATA drives. It's the perfect replacement for your SFF data-storage cables.
The cable is compatible with 6Gbps SATA drives.
  • Efficient connectivity
    The 1m Internal Mini SAS to SATA Cable facilitates a seamless connection between Serial ATA / SAS storage devices, ensuring a stable and reliable link for data transfer.
  • High compatibility
    Equipped with a 36 pin 4x Mini SAS HD (SFF-8643) plug and four 7 pin Serial ATA plugs, this cable supports a wide range of storage configurations, making it a versatile solution for various data management needs.
  • Quality assurance
    Adhering to RoHS compliant standards, this cable is manufactured with a commitment to environmental safety and high-quality material use, ensuring durability and longevity for all your storage needs.
StarTech.com 1m Internal Mini SAS to SATA Cable - SFF-8643 to 4x SATA (SAS43SAT1M) - SATA / SAS cable - 1 m
SATA / SAS cable
Length
1 m
Connector
36 pin 4x Mini SAS HD (SFF-8643) - plug
Connector (Second End)
4 x 7 pin Serial ATA - plug
Black & silver
P/N: SFF86448PLT2
Storage Cable Type
SATA / SAS cable
American Wire Gauge (AWG)
30
Length
1 m
Black & silver
44 g
Connector
RoHS
P/N: SFF86448PLT2
CHN7 StarTech.com 2x SFF-8643 to 8644 Adapter In Stock £68.29
Length: 1m
Type: SATA
