Connect a SAS controller to a SAS backplane. This internal mini-SAS cable provides a cost-saving solution for connecting a SAS or SATA adapter to a SAS or SATA backplane that has an SFF-8087 connection.
The cable is compatible with 12Gbps SAS drives as well as 6Gbps SATA drives.
High-speed connectivity
Experience rapid data transfer with the SAS 12Gbit/s interface speed, ensuring efficient communication between your devices. -
Durable design
Constructed with aluminum-polyester foil shielding, this cable is designed to resist interference, providing a reliable connection. -
Secure connection
Featuring latched connectors with a straight design, this cable provides a secure and stable connection, preventing accidental disconnections.
- StarTech.com 1m Internal Mini SAS Cable - SFF-8087 to SFF-8643 - Mini SAS to Mini SAS (SAS87431M) - SAS internal cable - 1 m
- Interface Speed
- SAS 12Gbit/s
- Technology
- Shielded
- Straight connector, latched
- Length
- 1 m
- Connector
- 36 pin 4x Mini SAS (SFF-8087) - plug
- Connector (Second End)
- 36 pin 4x Mini SAS HD (SFF-8643) - plug
- Black
- Limited lifetime warranty
- Designed For
- P/N: SFF86448PLT2
- Storage Cable Type
- Interface Speed
- SAS 12Gbit/s
- Technology
- Shielded
- Shielding Material
- Aluminium-polyester foil
- American Wire Gauge (AWG)
- 30
- Length
- 1 m
- Black
- 56 g
- Connector
- RoHS
- Designed For
- P/N: SFF86448PLT2
StarTech.com 2x SFF-8643 to 8644 Adapter | In Stock | £64.81 |
