StarTech.com 1m Right Angle USB C Cable
Quicklinx: D0K0WS00 Mfr#: USB2CC1MR
Length: 1m
15 in stock
£7.63 ex VAT
£9.15 inc VAT
Charge and sync your USB Type-C mobile devices, with the cable out of the way. This right-angle USB-C cable is great for charging your mobile devices in a car, or for accessing your phone or tablet while it's connected to a wall charger or laptop. The cable can also be used for charging your laptop from an AC charger.
The cable features a right-angled USB Type-C connector that lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices.
If you want to use your mobile device while it's charging, you can position the cable to the left or right of your device, in either portrait or landscape mode. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your mobile device, or keep one as a spare while traveling so that your mobile devices and laptop will be ready to use while you're on the road.
  • Connect with ease
    The cable features a right-angled USB Type C connector, that lets you connect to ports, that are difficult to reach, which is perfect for charging your car-mounted mobile devices. If you want to use your mobile device, while it's charging, you can position the cable to the left or right of your device, in either portrait or landscape mode. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way. The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
  • Power your laptop
    With optimal power output, you can use this USB Type C cable to power a USB-C laptop. Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
  • Keep as a spare while traveling
    Replace the USB-C cable, that came with your mobile device, or keep one as a spare while traveling, so that your mobile devices and laptop will be ready to use, while you're on the road.
StarTech.com Right-Angle USB-C Cable - M/M - 1 m (3 ft.) - USB 2.0 - USB-C cable - 1 m
USB-C cable
Length
1 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
USB / USB 2.0
USB-C cable
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
1 m
37 g
Connector
USB / USB 2.0, RoHS, WEEE
D0K0 StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £5.49
D0K0 StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £6.04
D0K0 StarTech.com 0.5m USB 2.0 USB C Cable In Stock £4.61
D0K0 StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £7.33
D0K0 StarTech.com 1m Right Angle USB C Cable In Stock £7.63
D0K0 StarTech.com 3m USB 2.0 Type C Cable In Stock £9.03
Length: 1m
Price Range Ex VAT: 0 - 50
