Product
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC
Quicklinx: 7Y0PWS00 Mfr#: 50FIBLCLC1
Length: 1m
14 in stock
£11.29 ex VAT
£13.54 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCLC1 1m LSZH LC to LC Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 1m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/LC - network cable - 1 m
Network cable
Fibre optic
Type of Fibre Optics
Multimode
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
P/N: ET91000LC
Network Cable Type
Network cable
Fibre optic
Multimode
50 / 125 micron
Length
1 m
Connector
P/N: ET91000LC
Length: 1m
Price Range Ex VAT: 0 - 50
