Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCLC1 1m LSZH LC to LC Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Efficient Data Transmission
The multimode duplex configuration allows for efficient data transmission, making it ideal for high-speed networking tasks. -
Robust Connector Types
Equipped with male LC connectors on both ends, this cable provides secure and reliable connections to networking devices. -
Suitable for Various Environments
The low smoke zero halogen (LSZH) material enhances safety in any environment by reducing smoke and toxic emissions during use. -
Optimum Performance Specifications
With a 50 / 125 micron core and cladding diameter, this fiber optic cable is engineered for performance and minimal signal loss.
- StarTech.com 1m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/LC - OM2 - LC to LC Fiber Patch Cable (50FIBLCLC1) - network cable - 1 m
- Network cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 1 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: 3CSFP91ST, ET91000LC, EXSFP1GESXST, GLCLHSM10PST, GLCLHSMD10ST, GLCLHSMDST, GLCLHSMDSTTA, GLCSXMM10PST, GLCSXMMDST, GLCSXMMDSTT, GLCSXMMRGDST, J4858C10PKST, J4858CST, J4859C10PKST, J4859CST, JD118BST, MASFP1GBSXST, SFP100BFXST, SFPF1302C, SFPGESST, SFPGLCLHSMST, SFPGLCSXMMST, SFPSXMM
- Network Cable Type
- Network cable
- Technology
- Multimode
- 50 / 125 micron
- Length
- 1 m
- Connector
- Designed For
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £23.49 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.56 |
