StarTech.com 1m Monitor VGA Cable
Quicklinx: 84N0WS00 Mfr#: MXTMMHQ1M
Length: 1m
33 In Stock
£6.05 ex VAT
£7.26 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ1M High Resolution VGA Cable (1-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
  • Reliable construction
    This VGA cable features a molded design and thumbscrews that ensure a stable and secure connection, preventing accidental disconnections during use.
  • Interference reduction
    The built-in ferrite core is designed to minimize electromagnetic interference, providing a clearer signal and an improved viewing experience.
  • Durability
    The cable is made with aluminum mylar foil and braid shielding, which protect against environmental damage and extend the cable's lifespan.
StarTech.com 1m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 1 m
VGA cable
Triple shielded twisted pair coaxial
Molded, thumbscrews, strain relief, ferrite core
Length
1 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, RoHS, NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
84N0 StarTech.com 1m Monitor VGA Cable In Stock £6.05
84N0 StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £7.32
84N0 StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £10.25
Length: 1m
