Charge and Sync your Micro USB-equipped Smartphone or Tablet. Looking for a replacement or spare charge cable for your Android phone or tablet? Tired of removing the case from your device for every charge and sync? Then this is the perfect standby cable for you.
The USBAUB1MBK 1m Micro USB Cable is colored to suit black mobile devices and provides a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
Reliable Connection
This USB cable features a double shielded design that provides a reliable connection for both charging and data transfer, minimizing interference and maximizing efficiency. -
Universal Compatibility
With compliance to USB 2.0 standards, this cable works seamlessly with a wide range of devices, making it a versatile choice for various applications. -
Durable Design
Constructed with nickel plated connectors, this cable offers enhanced durability and improved corrosion resistance, ensuring longevity and performance over time.
- StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable M/M - USB cable - Micro-USB Type B to USB - 1 m
- USB cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets | In Stock | £5.47 |
StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M | In Stock | £4.74 |
StarTech.com 3m USB / Slim Micro USB Cable | In Stock | £5.78 |
StarTech.com 20" Micro-USB Extension Cable | In Stock | £5.30 |
