Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM1M 1m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
Secure connection
The latched design of the connectors ensures a stable connection, preventing accidental disconnections during use. -
High-resolution support
This cable supports up to 4K resolution, providing crisp and clear video output, perfect for high-definition displays and multimedia applications. -
Durable construction
Built with a double shielded design and aluminum mylar foil with braid, this cable offers protection against electromagnetic interference and ensures long-lasting performance. -
Compatibility
Designed for Mac systems, this cable provides a seamless connection between your Mini DisplayPort devices and standard DisplayPort displays. -
Reliable performance
With a 32 AWG wire gauge, this cable delivers reliable performance in data transmission, making it suitable for gaming, video streaming, and professional presentations.
 - StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 1 m
 - DisplayPort cable
- Technology
 - Double shielded
 - Latched
- Length
 - 1 m
- Connector
 - Mini DisplayPort - male
- Connector (Second End)
 - DisplayPort - male
 - RoHS
 - Black
 - Limited lifetime warranty
 - DisplayPort cable
- Technology
 - Double shielded
- Shielding Material
 - Aluminum mylar foil with braid
- American Wire Gauge (AWG)
 - 32
- Plated Connector
 - Nickel
 - Latched
- Length
 - 1 m
 - Black
- Connector
 - 20 pin DisplayPort - male
 - RoHS
                        StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £3.70 |
                        StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.46 |
                        StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £13.08 |
                        StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.66 |
                        StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.91 |
