StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 7Q3XWS00 Mfr#: MDP2DPMM1M
Length: 1m
15 In Stock
£3.68 ex VAT
£4.41 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM1M 1m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
  • Secure connection
    The latched design of the connectors ensures a stable connection, preventing accidental disconnections during use.
  • High-resolution support
    This cable supports up to 4K resolution, providing crisp and clear video output, perfect for high-definition displays and multimedia applications.
  • Durable construction
    Built with a double shielded design and aluminum mylar foil with braid, this cable offers protection against electromagnetic interference and ensures long-lasting performance.
  • Compatibility
    Designed for Mac systems, this cable provides a seamless connection between your Mini DisplayPort devices and standard DisplayPort displays.
  • Reliable performance
    With a 32 AWG wire gauge, this cable delivers reliable performance in data transmission, making it suitable for gaming, video streaming, and professional presentations.
StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 1 m
DisplayPort cable
Double shielded
Latched
Length
1 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Double shielded
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Latched
Length
1 m
Connector
20 pin DisplayPort - male
RoHS
7Q3X StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.68
7Q3X StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.45
7Q3X StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £22.91
7Q3X StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.91
Length: 1m
