Know when your Micro-USB mobile devices are fully charged. Now you can know when your mobile devices are done charging without having to access them to find out. This Micro-USB charging cable features an LED indicator that lets you know when your mobile devices are fully charged.
The charge cable provides a visual that lets you know when your mobile device is charging, so you don't have to doubt whether or not the cable is plugged in correctly.
The LED indicator at the top of the Micro-USB connector lights up when the cable is connected to your device as well as a USB charger or USB port. A red light indicates that your device is still charging and a green light indicates that your device is fully charged.
Replace the cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
You don't have to remove the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro-USB connector molding that plugs into your device even while it's inside a protective case.
- StarTech.com 1m / 3ft USB to Micro USB Cable with LED Charging Light - M/M USB to Micro USB Charging Cable - USB Charger Cable (USBAUBL1M) - USB cable - Micro-USB Type B to USB - 1 m
- USB cable
- LED power indicator, sync and charge
- Length
- 1 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- Black
- 2-year warranty
- USB cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- RoHS
- 2-year warranty
