StarTech.com 1m LC/LC OM5 Fiber Cable
Quicklinx: HHX4WS00 Mfr#: LCLCL-1M-OM5-FIBER
Length: 1m
Colour: Green
20 In Stock
£18.45 ex VAT
£22.14 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, making this cable suitable for high-bandwidth applications and future-proofing your network infrastructure.
  • Enhanced durability
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion. It's designed to ensure safety in the event of a fire, making it suitable for use in densely populated environments.
  • Optimized for laser
    Featuring Laser-optimized multimode fibers (LOMMF) with a wavelength range of 840/953/1300 nm, this cable is engineered for optimal performance with Vertical Cavity Surface Emitting Lasers (VCSELs), supporting high-speed data transmission and reducing insertion loss.
  • Reliable connection
    The duplex LC to LC connectors provide a secure and stable connection, ensuring consistent performance and reliability for your network. The cable's bend-insensitive design further ensures signal integrity, even in tight spaces or around corners.
  • Eco-friendly choice
    Halogen-free and compliant with RoHS standards, this fiber optic cable is an environmentally friendly option, reducing harmful emissions and promoting a healthier planet.
StarTech.com 1m (3ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 1 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
1 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
1 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.5 cm
Shipping Weight
18 g
-20 °C
60 °C
HHX4 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £56.38
HHX4 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £18.45
HHX4 StarTech.com 20m LC/LC OM5 Fiber Cable In Stock £69.18
HHX4 StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.56
HHX4 StarTech.com 3m LC/LC OM5 Fiber Cable In Stock £24.53
HHX4 StarTech.com 7m LC/LC OM5 Fiber Cable In Stock £36.07
HHX4 StarTech.com 10m OM4 Multimode Fiber Cable In Stock £28.80
HHX4 StarTech.com 1m OM4 Multimode Fiber Cable In Stock £13.55
HHX4 StarTech.com 2m OM4 Multimode Fiber Cable In Stock £15.44
HHX4 StarTech.com 5m OM4 Multimode Fiber Cable In Stock £20.25
HHX4 StarTech.com 7m OM4 Multimode Fiber Cable In Stock £23.22
Length: 1m
Colour: Green
