The HDDVIMM10M 10-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Reliable shielding
The aluminum mylar foil with braid shielding effectively blocks interference, ensuring clear video signal transmission for optimal viewing experiences. -
Versatile compatibility
This cable supports both HDMI and DVI interfaces, making it suitable for a variety of devices including monitors, projectors, and TVs. -
High-quality connectors
With gold-plated connectors, this cable minimizes signal loss and provides a reliable connection to enhance video quality. -
PVC jacket material
The durable PVC jacket material protects the cable from damage, ensuring longevity and consistent performance over time. -
Eco-friendly design
This cable meets RoHS compliance standards, making it a responsible choice for environmentally conscious consumers.
- StarTech.com 1m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 1 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 1 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
StarTech.com 10m HDMI to DVI-D Cable - M/M | In Stock | £32.49 |
StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor | In Stock | £7.78 |
StarTech.com 3m HDMI to DVI-D Cable - M/M | In Stock | £9.25 |
StarTech.com 5m HDMI to DVI-D Cable – M/M | In Stock | £9.74 |
StarTech.com 1m HDMI to DVI-D Cable - M/M | In Stock | £7.31 |
StarTech.com 0.5m HDMI to DVI-D Cable - M/M | In Stock | £7.58 |
