StarTech.com 1m HDMI to DVI-D Cable - M/M
Quicklinx: 837PWS00 Mfr#: HDDVIMM1M
Length: 1m
£7.29 ex VAT
£8.74 inc VAT
The HDDVIMM10M 10-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
  • Reliable shielding
    The aluminum mylar foil with braid shielding effectively blocks interference, ensuring clear video signal transmission for optimal viewing experiences.
  • Versatile compatibility
    This cable supports both HDMI and DVI interfaces, making it suitable for a variety of devices including monitors, projectors, and TVs.
  • High-quality connectors
    With gold-plated connectors, this cable minimizes signal loss and provides a reliable connection to enhance video quality.
  • PVC jacket material
    The durable PVC jacket material protects the cable from damage, ensuring longevity and consistent performance over time.
  • Eco-friendly design
    This cable meets RoHS compliance standards, making it a responsible choice for environmentally conscious consumers.
StarTech.com 1m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 1 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
28
Length
1 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
28
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
837P StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.77
837P StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.65
837P StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £9.52
837P StarTech.com 15m HDMI to DIV-D Cable – M/M In Stock £11.48
837P StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.29
837P StarTech.com 0.5m HDMI to DVI-D Cable - M/M In Stock £7.60
Length: 1m
