StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9J50WS00 Mfr#: N6PATC1MGR
Length: 1m
Colour: Grey
More than 50 In Stock
£3.89 ex VAT
£4.66 inc VAT
StarTech.com Cat6 Snagless UTP patch cables are constructed with 24 gauge copper wire to support a broad range of Ethernet applications, such as Power over Ethernet (PoE), and feature specialized connector moldings that help prevent snags during cable runs. Because StarTech.com uses a high quality UL Listed 24 gauge insulated copper wire, its cables easily sustain the nominal voltage (48v) capability required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup and potentially equipment damage. All of StarTech.com Cat6 patch cables are wired to ANSI/TIA-568-B specifications.
StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Grey, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MGR) - patch cable - 1 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Snagless
Length
1 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
9J50 StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.90
9J50 StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.89
9J50 StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.86
9J50 StarTech.com 1m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.81
9J50 StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange In Stock £3.83
9J50 StarTech.com 1m Purple Cat6 Patch Cable In Stock £3.88
Length: 1m
Colour: Grey
