StarTech.com 1m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin)
Quicklinx: 8G3QWS00 Mfr#: DVIVGAMM1M
Length: 1m
£6.72 ex VAT
£8.06 inc VAT
Connect a VGA display to a PC or Mac with a DVI Analog Video Card. The DVIVGAMM1M DVI to VGA Display Monitor Cable (1m) features a DVI-A male connector and a VGA male connector, enabling you to connect a VGA display to a PC or Mac computer with a DVI-I analog output.
  • Durable construction
    The cable features a shielded design with aluminum mylar foil and braid, enhancing signal quality and durability.
  • Secure connection
    Equipped with molded connectors and thumbscrews, this cable ensures a secure and stable connection between devices.
  • Environmentally friendly
    Compliant with RoHS standards, this cable is designed with environmental considerations in mind.
StarTech.com 1m DVI to VGA Display Monitor Cable M/M DVI to VGA (15 Pin) - video cable - 1 m
Video cable
Shielded
Molded, thumbscrews, strain relief
Length
1 m
Connector
HD-15 (VGA) - male
Connector (Second End)
DVI-A - male
RoHS
Video cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Gold, nickel
Length
1 m
Connector
12+5 pin analogue DVI - male
RoHS
8G3Q StarTech.com 1m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin) In Stock £6.72
8G3Q StarTech.com 2m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin) In Stock £8.60
Length: 1m
