Brand
StarTech.com 1m DVI-D Dual Link Cable – M/M
Quicklinx: 87MMWS00 Mfr#: DVIDDMM1M
Length: 1m
More than 50 in stock
£7.89 ex VAT
£9.46 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM1M 1m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 1m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 1m DVID Dual Link Cable M/M - DVI cable - 1 m
DVI cable - dual link
Shielded
Thumbscrews
Length
1 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
RoHS
DVI cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
Thumbscrews
Length
1 m
Connector
24+1 pin digital DVI - male
RoHS
87MM StarTech.com 5m DVI-D Dual Link Cable – M/M In Stock £16.92
87MM StarTech.com 10m DVI-D Dual Link Cable – M/M In Stock £41.51
87MM StarTech.com 2m DVI-D Dual Link Cable – M/M In Stock £9.14
87MM StarTech.com 3m DVI-D Dual Link Cable – M/M In Stock £13.08
87MM StarTech.com 1m DVI-D Dual Link Cable – M/M In Stock £7.89
Length: 1m
Stock Status: In stock
