StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
Quicklinx: 8JFLWS00 Mfr#: SFPCMM1M
Length: 1m
Colour: Black
Hurry, only 2 left in stock!
£36.04 ex VAT
£43.24 inc VAT
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU1M cable. The SFPCMM1M Cisco Compatible 1m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU1M cable.
  • Reliable technology
    Utilizing twinaxial technology, this cable ensures reliable connectivity with minimal signal degradation, suitable for demanding networking environments.
  • Secure connections
    The latching connectors provide a secure fit, preventing accidental disconnections during operation and contributing to overall stability.
  • Versatile compatibility
    Compatible with SFP+ interfaces, this cable allows for easy integration with various networking devices, enhancing flexibility in network design.
  • Environmentally friendly
    This product meets RoHS compliance standards, reflecting a commitment to sustainability and safe usage.
StarTech.com Cisco SFP-H10GB-CU1M Compatible 1m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower ASR920 - Lifetime Warranty (SFPCMM1M) - direct attach cable - 1 m
Direct attach cable
Twinaxial
Latching connectors
Length
1 m
Connector
SFP+
Connector (Second End)
SFP+
P/N: ET10GSFP, PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
1 m
Connector
SFP+
SFP+
RoHS
70 °C
8JFL StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.04
8JFL StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.20
8JFL StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £45.82
8JFL StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £58.65
Length: 1m
Colour: Black
