StarTech.com 1m CAT8 Ethernet Cable, LSZH
Quicklinx: J1LMWS00 Mfr#: NLBL-1M-CAT8-PATCH
Hurry, only 3 left in stock!
£14.89 ex VAT
£17.86 inc VAT
The 1m Blue CAT8 Ethernet Cable from StarTech.com offers high-speed data transmission with capabilities of up to 40 Gbps. Designed for reliability, it features pure bare copper conductors that ensure optimal connectivity, enhanced by aluminum mylar foil shielding with braid for excellent EMI protection. This patch cable is flame-retardant and low smoke zero halogen, making it suitable for various environments while ensuring safety.
  • Robust shielding
    Constructed with aluminum mylar foil and braid, this cable provides excellent protection against electromagnetic interference, ensuring stable and reliable connections.
  • High data capacity
    With support for up to 40 Gbps and tested frequencies up to 2000 MHz, this cable is ideal for fast networking demands.
  • Flame retardant design
    This cable's flame retardant properties help in reducing fire risk, enhancing the overall safety of your network setup.
  • Durable construction
    Equipped with pure bare copper conductors and snagless design, it supports up to 750 mating cycles for long-lasting performance.
  • Wide compatibility
    This CAT8 Ethernet cable is compliant with IEEE 802.3bt and supports 100 W PoE++, making it suitable for various networking applications.
StarTech.com 1m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 1 m - blue
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
Length
1 m
Diameter
5.6 mm
Core / Cladding Diameter
50 micron
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
50 micron
Plated Connector
Gold
Length
1 m
Diameter
5.6 mm
Blue
Connector
RJ-45 - male
RJ-45 - male
TIA/EIA T568B - up to 2000 MHz
Shipping Width
22 cm
Shipping Depth
19.5 cm
Shipping Height
1 cm
Shipping Weight
56 g
50 °C
