The 1m Blue CAT8 Ethernet Cable from StarTech.com offers high-speed data transmission with capabilities of up to 40 Gbps. Designed for reliability, it features pure bare copper conductors that ensure optimal connectivity, enhanced by aluminum mylar foil shielding with braid for excellent EMI protection. This patch cable is flame-retardant and low smoke zero halogen, making it suitable for various environments while ensuring safety.
Robust shielding
Constructed with aluminum mylar foil and braid, this cable provides excellent protection against electromagnetic interference, ensuring stable and reliable connections. -
High data capacity
With support for up to 40 Gbps and tested frequencies up to 2000 MHz, this cable is ideal for fast networking demands. -
Flame retardant design
This cable's flame retardant properties help in reducing fire risk, enhancing the overall safety of your network setup. -
Durable construction
Equipped with pure bare copper conductors and snagless design, it supports up to 750 mating cycles for long-lasting performance. -
Wide compatibility
This CAT8 Ethernet cable is compliant with IEEE 802.3bt and supports 100 W PoE++, making it suitable for various networking applications.
- StarTech.com 1m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 1 m - blue
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
- Length
- 1 m
- Diameter
- 5.6 mm
- Core / Cladding Diameter
- 50 micron
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- 50 micron
- Plated Connector
- Gold
- Length
- 1 m
- Diameter
- 5.6 mm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 19.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 56 g
- 0 °C
- 50 °C
