StarTech.com 1m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H157WS00 Mfr#: NLBL-1M-CAT6A-PATCH
Length: 1m
Colour: Blue
27 In Stock
£7.87 ex VAT
£9.44 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 1m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Efficient Connection
    The RJ-45 connectors ensure a secure connection, enhancing overall transmission quality with gold plating.
  • Optimized Performance
    This cable features minimized Near-End Crosstalk (NEXT) for optimal performance in high-speed data transfers.
  • Durable Construction
    The molded design and strain relief feature provide durability and flexibility, making it ideal for both home and office environments.
  • Compliant Safety Standards
    The cable meets various compliance standards such as RoHS, ETL, and ANSI/TIA-568.2-D, ensuring it is safe and reliable for use.
  • Versatile Usage
    With a bandwidth of up to 500 MHz, this cable is suitable for various networking applications, supporting Power over Ethernet (PoE++).
StarTech.com 1m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 1 m - blue
Patch cable - CAT 6a
S/FTP
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, up to 10 Gbps
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
42.1 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1 cm
Shipping Weight
50.8 g
Length: 1m
Colour: Blue
