StarTech.com 1m CAT6a Ethernet Cable LSZH - Aqua
Quicklinx: H14LWS00 Mfr#: NLAQ-1M-CAT6A-PATCH
Length: 1m
Colour: Aqua
Hurry, only 3 left in stock!
£7.69 ex VAT
£9.22 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 1m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Reliable performance
    With up to 10 Gbps data transmission speeds and a tested frequency of 500 MHz, this CAT6a cable ensures high-quality networking and data transfer for a variety of applications.
  • Enhanced safety
    The Low Smoke Zero Halogen jacket reduces harmful fumes in case of fire, making this cable an optimal choice for environments that prioritize safety and compliance.
  • Durable design
    Featuring a molded construction with strain reliefs and a snagless design, this cable is built to withstand the rigors of daily use while preventing damage to connectors.
  • Robust shielding
    Utilizing foil shielding and compliant with RoHS and ETL standards, this cable provides optimal EMI/RFI protection and minimizes Near-End Crosstalk (NEXT) for a reliable connection.
  • High power delivery
    With the ability to handle a maximum input power of 100 W, this cable supports power over Ethernet applications, making it suitable for powering devices while ensuring stable data transmission.
StarTech.com 1m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 1 m - aqua
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Aqua
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
42.1 g
Aqua
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1 cm
Shipping Weight
50.8 g
Length: 1m
Colour: Aqua
