Extend your SuperSpeed USB 3.0 cable by up to an additional meter. The USB3SEXT1MBK Black SuperSpeed USB 3.0 extension cable (1m, A-A), offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 male to female cable extends a USB 3.0 cable connection by up to 1 meter and delivers the full USB 3.0 bandwidth of 5Gbps, supporting maximum throughput between compatible devices when used with a USB 3.0 host and device.
The USB 3.0 extension cord features high quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
Reliable connectivity
This USB extension cable features a male to female design with 9-pin USB Type-A connectors, ensuring a secure link between devices while supporting a variety of USB applications. -
Enhanced performance
Utilizing SFTP technology, the cable minimizes interference and maximizes performance, delivering consistent data transfer speeds. -
Robust construction
Constructed with nickel-plated connectors, this USB extension cable offers durability and long-lasting performance, making it suitable for frequent use across various environments. -
Cross-compatibility
The cable is compliant with USB / USB 2.0 / USB 3.0 standards, allowing compatibility with a wide range of devices and making it an essential addition to your tech accessories.
- StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - Male to Female USB 3 Extension Cable Cord 1 m (USB3SEXT1MBK) - USB extension cable - USB Type A to USB Type A - 1 m
- Technology
- Shielded foiled twisted pair (SFTP)
- Length
- 1 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, ST3300G3UA, ST3300GU3B, ST43004UA, ST4300MINI, ST7300U3M, SV211DPUA, SV211DPUA4K, SV211HDUA4K, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
- Technology
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
- P/N: 2SD4FCRU3, BNDDKT30CAHV, CFASTRWU3, FCREADMICRO3, MSDREADU3CA, ST3300G3UA, ST3300GU3B, ST43004UA, ST4300MINI, ST7300U3M, SV1631DUSBUK, SV211DPUA, SV211DPUA4K, SV211HDUA4K, SVUSB2N1_6, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB31GEHD, USB31GEVG, USB3SAA3MBK, USB3SMDOCKHV, USBA2DPGB
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £12.06 |
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.53 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.74 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.27 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.17 |
