Connect USB 3.0 devices, even in hard to reach areas and tight spaces. The USB3SAB2MRA 2m Black USB 3.0 A to B cable features a right-angled USB ''A'' male connector, enabling you to connect your USB 3.0 Type ''B'' peripherals to your PC, laptop, or server, even in hard to reach areas and tight spaces.
The right-angled USB ''A'' connector positions the cable nearly flush against a wall or other surface, and eliminates the space typically required to accommodate a ''straight'' connection from the cable into the USB port.
Harnessing the full capabilities of the SuperSpeed USB 3.0 standard when used with a USB 3.0 host and device, the 2m cable offers a bandwidth of 5Gbps.
Plus, this right angle USB 3.0 cable also features high quality Shielded Twisted Pair (STP) construction, which helps prevent electro-magnetic interference and ensure reliable data communication.
- StarTech.com 2m Black SuperSpeed USB 3.0 Cable - Right Angle A to B - M/M - USB cable - USB Type B to USB Type A - 2 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, right-angled connector, 5 Gbps data rate
- Length
- 2 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB / USB 2.0 / USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S3520BU33ER, S352BU33HR, S355BU33ERM, SDOCKU33EF
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, RoHS
- Designed For
