Extend the connection between your DB9 serial devices by up to 1m. The MXT1001MBK Black Serial Extension Cable (1m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
Reliable connectivity
This serial extension cable features a male 9-pin D-Sub connector on one end and a female version on the opposite end, ensuring effective connection for devices needing DB9 interfaces. -
Durable construction
Constructed with a shielded design and 28 AWG wire, this cable provides robust performance and long-lasting durability, accommodating various use cases. -
Nickel-plated connectors
The connectors are nickel-plated, which helps prevent corrosion and improves signal quality during data transmission. -
Environmentally friendly
This product complies with RoHS standards, taking a step towards reducing harmful materials and promoting sustainability in electronics.
- StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F (MXT1001MBK) - serial extension cable - DB-9 to DB-9 - 1 m
- Serial extension cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: 1P3FPC-USB-SERIAL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232IS, ICUSB232PRO, ICUSB232V2
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- RoHS
- Designed For
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.15 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £3.00 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.03 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.12 |
