Extend the connection between your DB9 serial devices by up to 1m. The MXT1001MBK Black Serial Extension Cable (1m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
- StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable (MXT1001MBK) - serial extension cable - DB-9 to DB-9 - 1 m
- Serial extension cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232IS, ICUSB232PRO, ICUSB232V2
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- RoHS
- Designed For
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £3.41 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.02 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.33 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £3.31 |
