StarTech.com 1m Aqua OM4 LC Fiber Cable
Quicklinx: CXPGWS00 Mfr#: 450FBLCLC1
Length: 1m
Colour: Aqua
Select:
30 In Stock
£17.33 ex VAT
£20.79 inc VAT
Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
  • Efficient data transmission
    The Aqua OM4 Duplex Multimode Fiber Patch Cable is designed to facilitate high-speed communication, making it suitable for applications that require excessive bandwidth and minimal signal loss.
  • Laser-optimized multimode fiber
    This cable features laser-optimized multimode fiber (LOMMF) that enhances the performance of 100 Gb networks, ensuring faster and more reliable data transfers.
  • Safety-focused jacket material
    Constructed with a low smoke zero halogen (LSZH) jacket, this cable limits harmful smoke emissions during a fire, ensuring safety in indoor environments.
  • Versatile duplex mode
    The duplex mode of this cable allows for simultaneous transmission and reception of data, significantly increasing network efficiency and performance.
  • Secure LC connectors
    With LC connectors on both ends, the cable provides a secure connection, minimizing the risk of accidental disconnections in active network setups.
StarTech.com Aqua OM4 Duplex Multimode Fiber - 1m / 3 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC1) - network cable - 1 m - aqua
Network cable - OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Laser-optimized multimode fibre (LOMMF)
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Network cable - OM4
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
50 / 125 micron
Length
1 m
Aqua
Connector
CXPG StarTech.com 1m Aqua OM4 LC Fiber Cable In Stock £17.33
CXPG StarTech.com 2m Aqua OM4 LC Fiber Cable In Stock £18.93
CXPG StarTech.com 5m Aqua OM4 LC Fiber Cable In Stock £21.30
CXPG StarTech.com 3m Aqua OM4 LC Fiber Cable In Stock £21.65
CXPG StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £38.07
CXPG StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua In Stock £30.82
CXPG StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £50.09
CXPG StarTech.com 10m OM4 Multimode Fiber Cable In Stock £28.11
CXPG StarTech.com 2m OM4 Multimode Fiber Cable In Stock £15.05
CXPG StarTech.com 3m OM4 Multimode Fiber Cable In Stock £16.31
CXPG StarTech.com 7m OM4 Multimode Fiber Cable In Stock £22.65
Length: 1m
Colour: Aqua
