MDP to DP Cable - DP 1.4 - 8K@60Hz - VESA Certified - Lifetime Warranty
This 1 meter VESA Certified Mini DisplayPort to DisplayPort v1.4 cable features a mDP male connector on one end, and a DP male latching connector on the other, allowing you to connect any Mini DisplayPort-enabled laptop or workstation to an 8K TV, monitor or projector that uses a standard DisplayPort connection.
Astonishing Picture Quality
This mDP to DP 1.4 cable supports high resolutions of up to 8K (7680 x 4320p) at 60Hz or 4K (3840 x 2160) at 120Hz with a maximum HBR3 bandwidth of 32.4 Gbps and ensures that digitally protected content is displayed properly, with both HDCP 2.2 and DPCP capability. The adapter cable also supports:
- Multi-Stream Transport (MST) for daisy chaining multiple monitors.
- Display Stream Compression (DSC) v1.2 transport that enables up to 3:1 compression ratio.
- HDR meta transport, which offers a flexible metadata packet transport to support future dynamic HDR standards.
- Expanded audio transport, which covers capabilities such as 32 uncompressed audio channels, 1536kHz sample rate.
- Forward Error Correction (FEC), which overlays the DSC 1.2 transport, addresses the transport error resiliency needed for compressed video transport to external displays.
Ultimate Compatibility
This Mini DisplayPort to DisplayPort adapter is compatible with several systems, including your PC, Mac and Microsoft Surface devices with mDP. For ultimate convenience, this Mini DisplayPort cable works with computers that are equipped with Thunderbolt 2 ports, enabling you to connect your DP compatible displays to your mDP source. In addition, this DP1.4 adapter cable supports a wide selection of mDP1.4-equipped graphics cards such as:
- Radeon VII, SSG, WX x100, Pro and FirePro series.
- Nvidia Quadro P series.
Built to Last
This Mini DisplayPort to DisplayPort v1.4 adapter cable is designed with gold-plated latching DisplayPort connectors that prevent accidental disconnection, making it a great accessory for office or boardroom applications.
Having 34 AWG conductors and 4.5mm outer diameter, this slim cable offers both flexibility and ease of connection.
The DP14MDPMM1MB is backed by a StarTech.com lifetime warranty and free lifetime technical support.
                ReliableBuilt with internal wire manager to ensure signal integrity. Al-Mylar foil with braid and metal connector sub-structure provide EMI shielding; latching connector on DP end to prevent accidental disconnection.
                DurablePVC jacket of this slim (outer diameter: 4.5mm) video cable (34 AWG) absorbs stress of frequent bends with strain relief protecting the core of the DisplayPort cord; gold-plated connectors prevent oxidization and tarnish.
                Astonishing picture qualityThis mDP to DP 1.4 cable supports high resolutions of up to 8K (7680 x 4320p) at 60Hz or 4K (3840 x 2160) at 120Hz with a maximum HBR3 bandwidth of 32.4 Gbps and ensures that digitally protected content is displayed properly, with both HDCP 2.2 and DPCP capability.
                Ultimate compatibilityThis Mini DisplayPort to DisplayPort adapter is compatible with several systems, including your PC, Mac, and Microsoft Surface devices with mDP. For ultimate convenience, this Mini DisplayPort cable works with computers that are equipped with Thunderbolt 2 ports, enabling you to connect your DP compatible displays to your mDP source.
- StarTech.com 3ft (1m) VESA Certified Mini DisplayPort to DisplayPort 1.4 Cable, 8K 60Hz HBR3 HDR, Super UHD mDP to DP 1.4 Cord, Slim (34 AWG) Ultra HD 4K 120Hz, Monitor/Video Cable - mDP to DP Cable (DP14MDPMM1MB) - DisplayPort cable - Mini DisplayPort to DisplayPort - 1 m
- DisplayPort cable
- 8K support, HBR3 support, maximum resolution 7680x4320 at 60Hz, HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport, Forward Error Correction, 19 conductors
- Length
- 1 m
- Connector
- Mini DisplayPort - male - latched
- Connector (Second End)
- 20 pin DisplayPort - male - latched
- DisplayPort 1.4
- Black
- Limited lifetime warranty
- DisplayPort cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 34
- Plated Connector
- Gold
- Length
- 1 m
- Outside Diameter
- 4.5 mm
- Black
- 2 cm
- 1.25 cm
- Connector
- DisplayPort 1.4, EMI, HDCP 2.2, DSC 1.2
- Shipping Width
- 22 cm
- Shipping Depth
- 2 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 75 g
