StarTech.com 1m 3ft USB 3.1 C to B Cable
Quicklinx: D5BNWS00 Mfr#: USB31CB1M
Length: 1m
18 in stock
£14.87 ex VAT
£17.84 inc VAT
Connect USB 3.1 or 3.0 USB-B devices to your USB-C host. Need to connect a new USB-C device to a USB-B device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
Plus, the cable provides up to 3A for powering your devices, where supported.
You'll also be able to connect your older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
StarTech.com USB 3.1 USB-C to USB-B Cable - USB-C cable - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type B - male
USB 3.1
Apple MacBook
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB 3.1, RoHS, USB-IF
Apple MacBook
D5BN StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.31
D5BN StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.41
D5BN StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.36
D5BN StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.26
D5BN StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £7.54
D5BN StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £12.59
D5BN StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.87
Length: 1m
Price Range Ex VAT: 0 - 50
