Connect USB 3.1 or 3.0 USB-B devices to your USB-C host. Need to connect a new USB-C device to a USB-B device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
Plus, the cable provides up to 3A for powering your devices, where supported.
You'll also be able to connect your older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
High-speed connectivity
Experience rapid data transfer with the USB C to USB B Printer Cable, featuring USB 3.1 technology that supports speeds up to 10 Gbps. This ensures efficient and quick printing jobs, making it ideal for both home and office use. -
Universal compatibility
Designed to connect seamlessly with any PC, this cable offers broad compatibility. Its USB-C and USB Type-B connectors cater to a wide range of devices, from printers to external hard drives, ensuring a reliable connection. -
Durable design
The double-shielded structure and nickel-plated connectors provide a robust build for the cable, enhancing its durability. This design minimizes interference and maintains the integrity of the signal, ensuring a stable and clear connection throughout its use.
- StarTech.com USB C to USB B Printer Cable - 1m / 3 ft - Superspeed - USB 3.1 - 10Gbps - USB C Printer Cable - USB Type C to Type B (USB31CB1M) - USB-C cable - 24 pin USB-C to USB Type B - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type B - male
- USB 3.1
- Black
- 2-year warranty
- Designed For
- P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, HBS304A24A, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312C2, PEXUSB312C3, S352BU313R, SDOCK2U313R, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6, TB33A1C
- USB-C cable
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB 3.1, RoHS, USB-IF
- 2-year warranty
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.72 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.68 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.37 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.11 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.66 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.61 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £15.04 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £18.04 |
