StarTech.com 1m 3ft USB 3.1 C to B Cable
Quicklinx: D5BNWS00 Mfr#: USB31CB1M
Length: 1m
More than 50 In Stock
£15.29 ex VAT
£18.34 inc VAT
Connect USB 3.1 or 3.0 USB-B devices to your USB-C host. Need to connect a new USB-C device to a USB-B device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
Plus, the cable provides up to 3A for powering your devices, where supported.
You'll also be able to connect your older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
  • High-speed connectivity
    Experience rapid data transfer with the USB C to USB B Printer Cable, featuring USB 3.1 technology that supports speeds up to 10 Gbps. This ensures efficient and quick printing jobs, making it ideal for both home and office use.
  • Universal compatibility
    Designed to connect seamlessly with any PC, this cable offers broad compatibility. Its USB-C and USB Type-B connectors cater to a wide range of devices, from printers to external hard drives, ensuring a reliable connection.
  • Durable design
    The double-shielded structure and nickel-plated connectors provide a robust build for the cable, enhancing its durability. This design minimizes interference and maintains the integrity of the signal, ensuring a stable and clear connection throughout its use.
StarTech.com USB C to USB B Printer Cable - 1m / 3 ft - Superspeed - USB 3.1 - 10Gbps - USB C Printer Cable - USB Type C to Type B (USB31CB1M) - USB-C cable - 24 pin USB-C to USB Type B - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type B - male
USB 3.1
P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, HBS304A24A, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312C2, PEXUSB312C3, S352BU313R, SDOCK2U313R, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6, TB33A1C
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB 3.1, RoHS, USB-IF
D5BN StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.74
D5BN StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
D5BN StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.61
D5BN StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.07
D5BN StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.22
D5BN StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
D5BN StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.61
D5BN StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
D5BN StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £12.71
D5BN StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.29
Length: 1m
