The MUHSMF1M 4-Pole 3.5mm headset extension cable (1m) features a 3.5mm (1/8" TRRS) audio connector on one end and a 3.5mm (1/8" TRRS) audio connector on the other, making it easy to extend the reach between your hands-free headset or headphones, and your iPhone, mobile phone or laptop computer.
To ensure long-lasting performance, this high quality 3.5mm audio extension cable features molded PVC strain relief at each of the 1/8" TRRS connectors, which prevents the cable termination points from bending at sharp angles, in turn reducing the risk of cable damage.
To ensure proper hardware detection, it's recommended that the external headset be plugged into the adapter first, before the adapter is connected to the computer or mobile device.
- StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F - audio Extension Cable for iPhone (MUHSMF1M) - headset extension cable - 1 m
- Cable
- Headset extension cable
- American Wire Gauge (AWG)
- 28
- Length
- 1 m
- Black
- Connector
- 4-pole mini jack - male
- Connector (Second End)
- 4-pole mini jack - female
- Moulded, strain relief
- Limited lifetime warranty
- Designed For
- P/N: MUYHSFMM, MUYHSMFF, MUYHSMFFADW, SV211DPUA, SV211DPUA4K, SV211HDUA4K
- Cable Type
- 28
- Jacket Material
- PVC
- Length
- 1 m
- Plated Connector
- Nickel
- Black
- Connector
- Mini-phone 3.5 mm 4-pole - male
- Mini-phone 3.5 mm 4-pole - female
- RoHS
- Limited warranty - lifetime
- Designed For
|  | StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
|  | StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
|  | StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.14 |
